Device Type not setting
Device type is not setting normally, I can set it manually, and if I run Discovery from Capture Debug Information it will set, but normally discovery, or from cli do not seem to set device type
LibreNMS 25.12.0 (2025-12-15T08:05:13-06:00)
DB Schema 2025_12_05_205509_devices_add_mtu_status (362)
PHP 8.3.6
Python 3.12.3
Database MariaDB 10.11.13-MariaDB-0ubuntu0.24.04.1
SNMP 5.9.4.pre2
[OK] Composer Version: 2.9.2
READ THIS FIRST:
Questions about *plugins* such as *Weathermap* should be posted in the Plugins category!!
https://community.librenms.org/c/plugins/15
./discovery.php -h HOSTNAME -d | curl --data-binary @- https://paste.rs/
./poller.php -h HOSTNAME -r -f -d | curl --data-binary @- https://paste.rs/
If you need to post any text longer than a few lines, please use a “pastebin” service, we recommend using https://paste.rs/ or https://paste.sh/
Discovery
Poller
Gives deprecated error, instead I ran
lnms device:poll -vvv HOSTNAME
This problem is present at least from 22th November. This is the time I saw it for the first time.
It doesn’t matter if I try to add device from web gui or from cli. Result is the same - device is added but no type is set. Tested on Mikrotik RouterOS devices.
Interesting is when I run
lnms device:discover
It does set the device type
I’m seeing exactly the same thing - when running ./discovery.php or the cron discovery it does not populate the device type but running lnms device:discover does work
@murrant device type setting looks to have been removed from discovery.php with this: Modern discovery by murrant · Pull Request #17813 · librenms/librenms · GitHub
Any reason or can we restore it?
I don’t think I removed it, probably only moved it.
Yes, it was moved outside the os module because it had to.
We have two options:
  1. restore the check into discovery.php somehow (it can’t be in the core module)
  2. stop using discovery.php and use lnms device:discover
Sorry I didn’t mean it was moved when it wasn’t supposed to, more that it was no longer where it used to be hence type no longer gets discovered.
Ideally we’d do #2 if it can be done quickly and safely.
