I have been having this issue for the last few days.
[FIX] Check the cron job to make sure it is running and using discovery-wrapper.py
I ran the following ( ./discovery.php -h all -v > /tmp/disco.txt & ) and the last few lines are posted below:
[email protected]
[/tmp]$ tail -20f disco.txt
[jnxBgpM2PeerLocalAddr] => 2A 04 E8 02 00 03 60 00 00 00 00 00 00 00 00 56
[jnxBgpM2PeerLocalPort] => 179
[jnxBgpM2PeerLocalAs] => 57976
[jnxBgpM2PeerRemoteAddrType] => ipv6
[jnxBgpM2PeerRemoteAddr] => 2A 04 E8 02 00 03 60 00 00 00 00 00 00 00 00 57
[jnxBgpM2PeerRemotePort] => 49986
[jnxBgpM2PeerRemoteAs] => 64976
[jnxBgpM2PeerIndex] => 76
[jnxBgpM2PeerRoutingInstance] => 0
peerindex for ipv4 4.53.230.237 is 11
Fatal error: Uncaught Error: Call to a member function getFamily() on null in /opt/librenms/includes/discovery/bgp-peers.inc.php:89
Stack trace:
#0 /opt/librenms/includes/discovery/functions.inc.php(175): include()
#1 /opt/librenms/discovery.php(125): discover_device(Array, Array)
#2 {main}
thrown in /opt/librenms/includes/discovery/bgp-peers.inc.php on line 89
I tried to send the disco.txt file into pbin.sh but the file is too large.
[email protected]
[/opt/librenms]$ more /tmp/disco.txt | ./pbin.sh
Paste endpoint: https://p.libren.ms/api/create
title:
private: 1
expire: 0
413 Request Entity Too Large
nginx/1.10.2
Can you edit includes/discovery/bgp-peers.inc.php
and insert the following before line 88 (before IP:fromHexString):
var_dump($entry['jnxBgpM2PeerRemoteAddr']);
Then paste the same output as before, you should have a little extra data before the Fatal error.
@murrant, below are the last few lines that you have asked for.
string(11) "04 35 E6 ED"
string(4) "&hT
PHP Fatal error: Uncaught Error: Call to a member function getFamily() on null in /opt/librenms/includes/discovery/bgp-peers.inc.php:90
Stack trace:
#2 {main}
thrown in /opt/librenms/includes/discovery/bgp-peers.inc.php on line 90
Stack trace:
#2 {main}
What the heck is &hT
That isn’t hex.
Scroll up a bit and past the snmp data from that entry. Should AFTER be jnxBgpM2PeerIndex => 11
The fix worked without any issues. Please let me know when it’s been merged into the master.
Updates applied to all Libre servers. Not seeing any more issues. OK to close.
