Hello, I am setting up monitoring for one of our newer Compellent 7020 series SAN I noticed that when it gets added it shows up as FreeBSD somesan.ourcompany.com 10.0-RELEASE-p11 FreeBSD 10.0-RELEASE-p11
I noticed a similar thread in an observium thread no observium links
And was wondering if I was having a similar issue. I did download the compellent mib and placed it in the /opt/librenms/mibs/
Im guessing that i might need to create an OS yaml file in /opt/librenms/includes/definitions
But Im honestly not sure what to add, or if i was not going about this quite right. example of discovery
/opt/librenms/discovery.php -d -m os -h 24
LibreNMS Discovery
Version info:
Commit SHA: 54deb1d429a983899e321447a7370270dccac568
DB Schema: 176
PHP: 7.0.16
MySQL: 5.5.52-MariaDB
RRDTool: 1.4.8
SNMP: NET-SNMP 5.7.2
DEBUG!
SQL[SELECT version FROM `dbSchema` ORDER BY version DESC LIMIT 1]
DB Schema already up to date.
SQL[SELECT * FROM `devices` WHERE status = 1 AND disabled = 0 AND `device_id` = '24' ORDER BY device_id DESC]
SQL[SELECT * FROM devices_attribs WHERE `device_id` = '24']
somesan.ourcompany.com 24 freebsd SQL[INSERT INTO `device_perf` (`xmt`,`rcv`,`loss`,`min`,`max`,`avg`,`device_id`,`timestamp`) VALUES ('3','3','0','13.0','13.2','13.0','24',NOW())]
SNMP Check response code: 0
Modules status: Global+ OS Device
#### Load disco module os ####
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Ovq -M /opt/librenms/mibs udp:HOSTNAME:161 SNMPv2-MIB::sysDescr.0]
FreeBSD somesan.ourcommpany.com 10.0-RELEASE-p11 FreeBSD 10.0-RELEASE-p11 #0: Thu Dec 15 17:22:17 CST 2016 [email protected]:/work/buildmaster/r07.01.04/R*/07_01_04_004/work/buildmaster/r07.01.04/R*/src/sys/COMPELLENT amd64
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Ovqn -M /opt/librenms/mibs udp:HOSTNAME:161 SNMPv2-MIB::sysObjectID.0]
.*.4.1.8*
| FreeBSD somesan.ourcompay.com 10.0-RELEASE-p11 FreeBSD 10.0-RELEASE-p11 #0: Thu Dec 15 17:22:17 CST 2016 [email protected]:/work/buildmaster/r07.01.04/R07.01.04.004/07_01_04_004/work/buildmaster/r07.01.04/R07.01.04.004/src/sys/COMPELLENT amd64 | .1.3.6.1.4.1.8072.3.2.8 |
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Oqvn -M /opt/librenms/mibs udp:HOSTNAME:161 ENTITY-MIB::entPhysicalDescr.1]
No Such Object available on this agent at this OID
>> Runtime for discovery module 'os': 0.2490 seconds with 3056 bytes
#### Unload disco module os ####
SQL[SELECT attrib_value FROM devices_attribs WHERE `device_id` = '24' AND `attrib_type` = 'poll_mib' ]
SQL[UPDATE `devices` set `last_discovered` =NOW(),`last_discovered_timetaken` ='0.712' WHERE `device_id` = '24']
Discovered in 0.712 seconds
SQL[INSERT INTO `perf_times` (`type`,`doing`,`start`,`duration`,`devices`,`poller`) VALUES ('discover','24','1489428899.2588','0.747','1','GoodyearLibreNMS\n')]
/opt/librenms/discovery.php 24 2017-03-13 14:15:00 - 1 devices discovered in 0.747 secs
SNMP: Get[4/0.18s] Walk [0/0.00s]
MySQL: Cell[3/0.00s] Row[1/0.00s] Rows[4/0.00s] Column[0/0.00s] Update[1/0.00s] Insert[2/0.00s] Delete[0/0.00s]
I am hoping someone can point me in the right direction.
jgoodyear
