Distributed Poller stops graphs
Hi All,
After setting up Distributed Poller for some reason my graphs just stop ‘error drawing graphs’
The new Poller has 0 host so my Default poller is still polling everything if I disable the Distributed Poller all is fixed then.
#Pollers
#Graphs
#./validate.php
Main Poller
LibreNMS 1.60-52-gc136e1ad6
DB Schema 2020_02_10_223323_create_alert_location_map_table (159)
PHP 7.2.27-6+ubuntu18.04.1+deb.sury.org+1
MySQL 10.1.44-MariaDB-0ubuntu0.18.04.1
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
[OK] Composer Version: 1.9.3
[FAIL] Some devices have not completed their polling run in 5 minutes, this will create gaps in data.
Check your poll log and see: Performance - LibreNMS Docs
Devices:
csw-01-isd-tdc-za.ionline.co.za
Second Poller
LibreNMS | 1.60-52-gc136e1ad6
DB Schema | 2020_02_10_223323_create_alert_location_map_table (159)
PHP | 7.2.27-6+ubuntu18.04.1+deb.sury.org+1
MySQL | 10.1.44-MariaDB-0ubuntu0.18.04.1
RRDTool | 1.7.0
SNMP | NET-SNMP 5.7.3
        Devices:
RRDTool Output
ERROR: rrdcached: /mnt/data-01/rrd/xx.xx.xx.xx/storage-hrstorage-Filesystem__.rrd: Permission denied
This fixed the issue.
chown librenms:librenms rrdcached.*
chmod 755 rrdcached.*
