Hi Guys,
Firstly sorry if this has come up before I did look around and found similar topics but nothing as specific.
So I’ve just finished setting up distributed polling with my central box in the UK and the poller in Asia hitting local devices. I naively hoped that this would resolve my long polling times as my checks were running across an internet VPN.
Instead they remain pretty much the same, I’ve moved the latency issue away from the snmp GET/Walk to the SQL functions.
Poller results run from the UK:
#### End Alerts ####
SNMP: Get[21/6.00s] Walk [27/168.31s]
MySQL: Cell[44/0.02s] Row[2/-0.01s] Rows[20/0.02s] Column[3/0.00s] Update[283/0.08s] Insert[2/0.00s] Delete[0/0.00s]
Poller results run from the Asia poller:
SNMP: Get[21/0.44s] Walk [27/32.98s]
MySQL: Cell[44/34.39s] Row[3/-22.14s] Rows[21/9.23s] Column[3/1.30s] Update[283/73.94s] Insert[2/1.56s] Delete[0/0.00s]
Basically I’m now stuck for ideas on improving this as disabling poller modules or segregating modules out to more pollers wont solve the distance issue.
