Hi All,
For some reason when I add a new device on my secondary poller the RRD files are created on my Main Poller and the secondary poller RRD directory is empty.
anyone else got this issue?
Hi All,
The secondary poller shouldnt have rrds. If I remember correctly, the secondary poller will only create rrds if cant connect to the main install.
Ah okay but the moment the RRD’s are on the Main install the graphs are empty, weird thing is that this issue is only on Routers.
