Hi !
We have a duplicate usage of panSessionActive on LibreNMS
In the overview page
And in “graph”, “firewall”
In have create en PR for patching the overview and add the SSL Proxy usage but i don’t know if it’s usefull …
librenms:master
← mathieu-oui:fix-sessions-panos
opened 05:52PM - 24 Mar 20 UTC
same as https://github.com/librenms/librenms/pull/10658 + update mibs
![image… ](https://user-images.githubusercontent.com/62615280/79319799-16ab9c00-7f09-11ea-9afc-c6360605eab9.png)
DO NOT DELETE THIS TEXT
#### Please note
> Please read this information carefully. You can run `./scripts/pre-commit.php` to check your code before submitting.
- [x] Have you followed our [code guidelines?](http://docs.librenms.org/Developing/Code-Guidelines/)
- [ ] If my Pull Request does some changes/fixes/enhancements in the WebUI, I have inserted a screenshot of it.
#### Testers
After you are done testing, you can remove the changes with `./scripts/github-remove`. If there are schema changes, you can ask on discord how to revert.
What is the best option for this duplicate ?
Thank’s of your reply
Graph was there, Count sensor was recently added. And Count sensor is more insteresting than the graph cause it can be used for alerting. So only Count Sensor will survive in fine.
If count sensor is not working, it must be of course fixed.
If the value is always 0, probably the num_oid is wrong. Run the poller with -v and -d parameter to troubleshoot that.
Ok for me, i will add count for SSL Proxy and load for Session + SSL Proxy too
