Environmental Sensor external temp sensors not displaying
I’ve updated the MIB in the system it was from 2012 to their latest available. serverscheck
Is there some other procedure to get the additional external sensors to be discovered/probed?
p.libren.ms/view/ff2dbc6f
p.libren.ms/view/07a048e5
p.libren.ms/view/43aafc39
When I walk it manually I see the other sensors that I wish to have graphed…
Ex. Temp2 Dewpoint / Humidty2 etc
.1.3.6.1.4.1.17095.1000
iso.3.6.1.4.1.17095.1000.1.1.0 = STRING: “Intttt. Temp1”
iso.3.6.1.4.1.17095.1000.1.2.0 = STRING: “Int. Temp”
iso.3.6.1.4.1.17095.1000.1.3.0 = STRING: “73.76”
iso.3.6.1.4.1.17095.1000.1.4.0 = INTEGER: 73
iso.3.6.1.4.1.17095.1000.1.5.0 = STRING: “DOWN”
iso.3.6.1.4.1.17095.1000.1.6.0 = INTEGER: 2
iso.3.6.1.4.1.17095.1000.1.7.0 = STRING: “DOWN”
iso.3.6.1.4.1.17095.1000.1.8.0 = STRING: “05 June 2020,11:52:13”
iso.3.6.1.4.1.17095.1000.2.1.0 = STRING: “Int. Ping1”
iso.3.6.1.4.1.17095.1000.2.2.0 = STRING: “Int. Ping”
iso.3.6.1.4.1.17095.1000.2.3.0 = STRING: “0.00”
iso.3.6.1.4.1.17095.1000.2.4.0 = INTEGER: 0
iso.3.6.1.4.1.17095.1000.2.5.0 = STRING: “NORMAL”
iso.3.6.1.4.1.17095.1000.2.6.0 = INTEGER: 0
iso.3.6.1.4.1.17095.1000.2.7.0 = STRING: “-”
iso.3.6.1.4.1.17095.1000.2.8.0 = STRING: “-”
iso.3.6.1.4.1.17095.1000.3.1.0 = STRING: “Ext. Temp1”
iso.3.6.1.4.1.17095.1000.3.2.0 = STRING: “Ext. Temp”
iso.3.6.1.4.1.17095.1000.3.3.0 = STRING: “73.62”
iso.3.6.1.4.1.17095.1000.3.4.0 = INTEGER: 73
iso.3.6.1.4.1.17095.1000.3.5.0 = STRING: “DOWN”
iso.3.6.1.4.1.17095.1000.3.6.0 = INTEGER: 2
iso.3.6.1.4.1.17095.1000.3.7.0 = STRING: “DOWN”
iso.3.6.1.4.1.17095.1000.3.8.0 = STRING: “05 June 2020,11:52:17”
iso.3.6.1.4.1.17095.1000.4.1.0 = STRING: “Humidity1”
iso.3.6.1.4.1.17095.1000.4.2.0 = STRING: “Humidity”
iso.3.6.1.4.1.17095.1000.4.3.0 = STRING: “54.68”
iso.3.6.1.4.1.17095.1000.4.4.0 = INTEGER: 54
iso.3.6.1.4.1.17095.1000.4.5.0 = STRING: “NORMAL”
iso.3.6.1.4.1.17095.1000.4.6.0 = INTEGER: 0
iso.3.6.1.4.1.17095.1000.4.7.0 = STRING: “-”
iso.3.6.1.4.1.17095.1000.4.8.0 = STRING: “-”
iso.3.6.1.4.1.17095.1000.5.1.0 = STRING: “Dew Point1”
iso.3.6.1.4.1.17095.1000.5.2.0 = STRING: “Dew Point”
iso.3.6.1.4.1.17095.1000.5.3.0 = STRING: “64.57”
iso.3.6.1.4.1.17095.1000.5.4.0 = INTEGER: 64
iso.3.6.1.4.1.17095.1000.5.5.0 = STRING: “DOWN”
iso.3.6.1.4.1.17095.1000.5.6.0 = INTEGER: 2
iso.3.6.1.4.1.17095.1000.5.7.0 = STRING: “DOWN”
iso.3.6.1.4.1.17095.1000.5.8.0 = STRING: “05 June 2020,11:52:17”
iso.3.6.1.4.1.17095.1000.6.1.0 = STRING: “Ext. Temp2”
iso.3.6.1.4.1.17095.1000.6.2.0 = STRING: “Ext. Temp”
iso.3.6.1.4.1.17095.1000.6.3.0 = STRING: “72.84”
iso.3.6.1.4.1.17095.1000.6.4.0 = INTEGER: 72
iso.3.6.1.4.1.17095.1000.6.5.0 = STRING: “DOWN”
iso.3.6.1.4.1.17095.1000.6.6.0 = INTEGER: 2
iso.3.6.1.4.1.17095.1000.6.7.0 = STRING: “DOWN”
iso.3.6.1.4.1.17095.1000.6.8.0 = STRING: “05 June 2020,11:52:17”
iso.3.6.1.4.1.17095.1000.7.1.0 = STRING: “Humidity2”
iso.3.6.1.4.1.17095.1000.7.2.0 = STRING: “Humidity”
iso.3.6.1.4.1.17095.1000.7.3.0 = STRING: “53.17”
iso.3.6.1.4.1.17095.1000.7.4.0 = INTEGER: 53
iso.3.6.1.4.1.17095.1000.7.5.0 = STRING: “NORMAL”
iso.3.6.1.4.1.17095.1000.7.6.0 = INTEGER: 0
iso.3.6.1.4.1.17095.1000.7.7.0 = STRING: “WARNING”
iso.3.6.1.4.1.17095.1000.7.8.0 = STRING: “04 June 2020,15:52:10”
iso.3.6.1.4.1.17095.1000.8.1.0 = STRING: “Dew Point2”
iso.3.6.1.4.1.17095.1000.8.2.0 = STRING: “Dew Point”
iso.3.6.1.4.1.17095.1000.8.3.0 = STRING: “63.47”
iso.3.6.1.4.1.17095.1000.8.4.0 = INTEGER: 63
iso.3.6.1.4.1.17095.1000.8.5.0 = STRING: “DOWN”
iso.3.6.1.4.1.17095.1000.8.6.0 = INTEGER: 2
iso.3.6.1.4.1.17095.1000.8.7.0 = STRING: “DOWN”
iso.3.6.1.4.1.17095.1000.8.8.0 = STRING: “05 June 2020,11:52:17”
iso.3.6.1.4.1.17095.1000.9.1.0 = STRING: “-”
iso.3.6.1.4.1.17095.1000.9.2.0 = STRING: “-”
iso.3.6.1.4.1.17095.1000.9.3.0 = STRING: “-”
iso.3.6.1.4.1.17095.1000.9.4.0 = INTEGER: 255
iso.3.6.1.4.1.17095.1000.9.5.0 = STRING: “-”
iso.3.6.1.4.1.17095.1000.9.6.0 = INTEGER: 255
iso.3.6.1.4.1.17095.1000.9.7.0 = STRING: “-”
iso.3.6.1.4.1.17095.1000.9.8.0 = STRING: “-”
iso.3.6.1.4.1.17095.1000.10.1.0 = STRING: “-”
iso.3.6.1.4.1.17095.1000.10.2.0 = STRING: “-”
iso.3.6.1.4.1.17095.1000.10.3.0 = STRING: “-”
iso.3.6.1.4.1.17095.1000.10.4.0 = INTEGER: 255
iso.3.6.1.4.1.17095.1000.10.5.0 = STRING: “-”
iso.3.6.1.4.1.17095.1000.10.6.0 = INTEGER: 255
iso.3.6.1.4.1.17095.1000.10.7.0 = STRING: “-”
iso.3.6.1.4.1.17095.1000.10.8.0 = STRING: “-”
