Error 1062 when poller runs
A couple of days ago this error stated coming in once an hour. The duplicate entry is the hostname of my librenms server. I dont know how a duplicate could have been created. I am no db admin and havent been in it.
pymysql.err.IntegrityError: (1062, “Duplicate entry ‘vm-umfs-librenms’ for key ‘pollers_poller_name_unique’”)
Here is the full output for the error.
https://p.libren.ms/view/9f674258
validate:
LibreNMS 22.7.0-30-g3309750f3
DB Schema 2022_07_19_081224_plugins_unique_index (244)
PHP 7.4.30
Python 3.9.2
Database MariaDB 10.5.15-MariaDB-0+deb11u1
SNMP 5.9
[OK] Composer Version: 2.3.10
[OK]
[OK] MySQl and PHP time match
[WARN] PHP version 8.1 is the minimum supported version as of September, 2022. We recommend you update PHP to a supported version (8.1 suggested) to continue to receive updates. If you do not update PHP, LibreNMS will continue to function but stop receiving bug fixes and updates.
Are you using distributed polling ? if so how many pollers ?
poller_name field must be unique
MariaDB [librenms]> explain pollers;
| Field | Type | Null | Key | Default | Extra |
| id | int(10) unsigned | NO | PRI | NULL | auto_increment |
| poller_name | varchar(255) | NO | UNI | NULL | |
| last_polled | datetime | NO | | NULL | |
| devices | int(10) unsigned | NO | | NULL | |
| time_taken | double | NO | | NULL | |
5 rows in set (0.001 sec)
you can check the entries in pollers table with below command
select * from pollers;
No other pollers. Just the one librenms server.
When I run select * from pollers; I just get a flashing curser
5 rows in set (0.004 sec)
MariaDB [librenms]> select * from pollers
Here is my config:
Have a look in misc/config_definitions.json for examples of settings you can set here. DO NOT EDIT misc/config_definitions.json!
// This is the user LibreNMS will run as
//Please ensure this user is created and has the correct permissions to your install
#$config[‘user’] = ‘librenms’;
This should only be set if you want to force a particular hostname/port
It will prevent the web interface being usable form any other hostname
#$config[‘base_url’] = “/”;
Enable this to use rrdcached. Be sure rrd_dir is within the rrdcached dir
and that your web server has permission to talk to rrdcached.
#$config[‘rrdcached’] = “unix:/var/run/rrdcached.sock”;
Default community
$config[‘snmp’][‘community’] = array(‘‘);
$config[‘snmp’][‘community’] = array(’
Authentication Model
#$config[‘auth_mechanism’] = “mysql”; # default, other options: ldap, http-auth
#$config[‘http_auth_guest’] = “guest”; # remember to configure this user if you use http-auth
List of RFC1918 networks to allow scanning-based discovery
$config[‘nets’] = “10.0.0.0/8”;
$config[‘nets’] = “172.16.0.0/12”;
$config[‘nets’] = “192.168.0.0/16”;
$config[‘nets’] = “100.100.0.0/16”;
Uncomment the next line to disable daily updates
#$config[‘update’] = 0;
Number in days of how long to keep old rrd files. 0 disables this feature
#$config[‘rrd_purge’] = 0;
Uncomment to submit callback stats via proxy
#$config[‘callback_proxy’] = “hostname:port”;
Set default port association mode for new devices (default: ifIndex)
$config[‘default_port_association_mode’] = ‘ifIndex’;
Enable the in-built billing extension
#$config[‘enable_billing’] = 1;
Enable the in-built services support (Nagios plugins)
$config[‘show_services’] = 1;
$config[‘nagios_plugins’] = “/usr/lib/nagios/plugins”;
$config[‘discover_services’] = true;
$config[‘discover_services_templates’] = true;
$config[‘service_poller_enabled’] = true;
$config[‘service_discovery_enabled’] = true;
$config[‘service_services_enabled’] = true;
“;” is missing in query
Thanks,
MariaDB [librenms]> select * from pollers;
| id | poller_name | last_polled | devices | time_taken |
| 43 | vm-umfs-librenms | 2022-08-04 09:21:25 | 39 | 82 |
1 row in set (0.001 sec)
Should I delete that poller? It looks like it should be there. Thats the name of my libenms vm.
I backed up the DB then deleted that entry. It just came back as a different id and still throws the same error.
I also just received this error. I hope this may give us a clue.
We just attempted to update your install but failed. The information below
should help you fix this.
error: cannot lock ref ‘refs/remotes/origin/master’: is at
c25629343fcd1879e76cdc4899c9b8e4f2769118 but expected
0f37f68bfdfa5a30fbe2509c7eafc945a4b6df37
Anybody have any suggestions?
