Long-time user here who never needed help till now. This is a new-ish install (4 months) and I’ve mostly ignored this issue till now. The event log is continually spammed with lines like this:
Failed to create rrd directory: /data/librenms/rrd//
for every device on every poll. Yet the directory is already there, owner and perms are correct, FS is XFS, distro is AlmaLinux-9.4
Apart from this spam in the event logs, this LibreNMS works fine, no issues, no complaints. Discovery, polling, graphs, alerts, dashboard all totally satisfactory.
More than 1 person had this error in the past (I found 4) and I followed them all down, no luck. Most of them were related to rrdcached or using docker. I have neither - no docker and don’t use rrdcached. This is a standard install, no funnies, I followed the official docs. The only difference is RRDs are stored in /data (company standard), but IIRC they issue was there when they were in /opt/librenms/rrd as well. Validate is clean. The 4 usual commands to chown/chmod/setfacl were run, and I updated to v24.9 and php-8.2 just last week.
I did initially think it was an exception in function***** in app/Jobs/PollDevice.php as that is the only instance of “Failed to create rrd directory” that grep -ir can find in /opt/librenms. But it’s not that function, I commented out the entire if/try/catch block and it still happens! Also, all the usual mistakes and errors that get mentioned here over and over have been checked, more than once. Reproducing this fault here is simply to enable polling.
So I am mystified and am reaching out for help, I might need assistance with tracing the running code to narrow this down
Validate:
librenms@librenms-jh01 ~ $ ./validate.php
| LibreNMS | 24.9.1 (2024-09-30T01:40:22+02:00) |
| DB Schema | 2024_03_27_123152_create_transceivers_table (300) |
| PHP | 8.2.13 |
| Python | 3.9.18 |
| Database | MariaDB 10.5.22-MariaDB |
| RRDTool | 1.7.2 |
| SNMP | 5.9.1 |
[OK] Composer Version: 2.6.6
Discovery: https://p.libren.ms/view/b337ad4e
Poller: https://p.libren.ms/view/02bf2e20
Thanks, Alan
