Hi Expert,
I facing error as per below. Another issue was when i click to the graph port it said “404 error”.
librenms@ubuntu:~$ ./validate.php
| LibreNMS | 24.11.0 (2024-11-20T14:58:54+00:00) |
| DB Schema | 2024_11_07_110342_custommap_edge_add_text_align (307) |
| PHP | 8.3.14 |
| Python | 3.10.12 |
| Database | MariaDB 10.6.18-MariaDB-0ubuntu0.22.04.1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.1 |
[OK] Composer Version: 2.8.3
[FAIL] Scheduler is not running
sudo cp /opt/librenms/dist/librenms-scheduler.service /opt/librenms/dist/librenms-scheduler.timer /etc/systemd/system/
sudo systemctl enable librenms-scheduler.timer
sudo systemctl start librenms-scheduler.timer
