hi,
- i can see in the logs: Component: (42899). Attribute: currentup, was modified from: 5, to: 4
but no indication for that attribute in Component table in the database.
i wanna write alert based on currentup value. - type f5-ltm-poolmember in the Component table only writes the pool-name. it should be the node -name/node_ip. there is no difference in f5-ltm-pool and f5-ltm-poolmember.
thx
