First Thanks for a great program.
I think I found an issue:
I have a Alert template cut down to nothing like this: Alert Template - Pastebin.com
And Alert response is correct and timing is perfect. looking like so: Alert Mail - Pastebin.com
But when an port, storage or CPU Recovers. And you get the recovery mail from the alert.
Ports will still appear down, storage free space is the same from the Alerts occurred and CPU load is the same from alerts moment not the recovery moment:
so recovery mail looks like so: Recovery Mail - Pastebin.com
I would like to have the last state of the device when I get a mail. not sure is intended or not.
or possible to call %ports.ifOperStatus some like that.
Thanks in advance, hope you understand. If I need to provide more info, please say
This is currently how it works, it’s not a bug and I’m not sure what we can do to fix it. We don’t have the fresh data based on the way the alerting works
