Which port is your oxidized listening on? You can’t bind both nginx/apache webserver and oxidized on the same 80/444 port, so if you run them on the same server you mostly will have oxidized listening under a different port.
Btw what I do, is run oxidized as a systemd service, but it runs in a docker/podman container. Saves you the trouble of getting all dependencies correct for oxidized otherwise.
@Killo:
Even if I take exactly your lines for config.php, the WebGUI is dead (blank)
Immediatley after removing the “faulty” lines and even without restarting nginx it works again.
@Elias:
Do’nt know sure, because I use CentOS OVA. But looking at the VirtualBox Settings it should be librenms port 80 (portforwarding 8080 --> 80) and oxidized 8888 (portforwarding 8888 --> 8888)
And as I said, the librenms webGUI is blank/not responding and oxidized is no starting
Update:
did not change anything, but with
$config[‘oxidized’][‘maps’][‘group’][‘hostname’][] = array(‘regex’ => ‘/192/’, ‘group’ => ‘DMZ’);
there is no error, but it not working.
When I try
$config[‘oxidized’][‘maps’][‘group’][‘hostname’][] = array(‘regex’ => ‘/^192/’, ‘group’ => ‘DMZ’);
OR
$config[‘oxidized’][‘maps’][‘group’][‘hostname’][] = array(‘regex’ => ‘/192*/’, ‘group’ => ‘DMZ’);
OR
$config[‘oxidized’][‘maps’][‘group’][‘hostname’][] = array(‘regex’ => ‘/192.168.103.11/’, ‘group’ => ‘DMZ’);
the error is like
[librenms@localhost ~]$ curl -H 'X-Auth-Token: 19e35a0b60510fc81852209357b8df0c' http://localhost/api/v0/oxidized
{"message": "Server Error: Set APP_DEBUG=true to see details."}
AND
[librenms@localhost ~]$ oxidized
no implicit conversion of String into Integer
Update 2:
setting enable, url and reload still does not work with config.php.
But now the following “override” or group-mapping works:
$config['oxidized']['maps']['group']['hostname'][] = array('regex' => '/^192/', 'group' => 'DMZ');
wtf… it’s not first time I try this
Update 3:
ok. the syntax. ‘ against ’
END:
So this works for me (on CentOS OVA):
nano /opt/librenms/config.php
$config['oxidized']['enabled'] = true;
$config['oxidized']['url'] = 'http://127.0.0.1:8888';
$config['oxidized']['features']['versioning'] = true;
$config['oxidized']['group_support'] = true;
$config['oxidized']['default_group'] = 'default';
$config['oxidized']['reload_nodes'] = true;
$config['oxidized']['maps']['group']['hostname'][] = array('regex' => '/^172/', 'group' => 'LAN');
nano /opt/librenms/.config/oxidized/config
groups:
DMZ:
username: usr1
password: pwd1
model: procurve
LAN:
username: usr2
password: pwd2
model: procurve
default:
username: manager
password: pw3
model: procurve
output:
default: git
git:
user: librenms
email: [email protected]
repo: "/opt/librenms/.config/oxidized/git/default.git"
source:
default: http
debug: false
http:
url: http://localhost/api/v0/oxidized
map:
model: os
ip: ip
group: group
headers:
X-Auth-Token: 'my_api_key'
Incorrect delimiters can definitely break things, you should always use the single quote and not backticks.
But it’s working now?
yes its working now with my provided configuration.
Thank for your help, Killo and Elias!
Cool, glad to heat that
And you’re welcome!
glad you got it squared away brother. Nice work!
