Hi guys!!
Is possible to graph the connection tracking count of one Mikrotik firewall?
The Mikrotik OID has this value? If is yes, how can I graph that.
Is very useful to detect networks problems.
Thanks for your help.
Hi @cbotejara
As you have the device in front of you, I would suggest you try to find the OID and value. If you find it, then you could either add it or submit an issue with this request, and provide all the required data for it.
https://docs.librenms.org/Support/FAQ/#faq20
PipoCanaja
