I need some help on debugging why I am not able to open the Weathermap editor
when I click on the link “here to access the editor” under Overview/Plugins/Weathermap.
In my logfiles is shown that it still worked yesterday…
Actually I renamed ~/html/plugins/Weathermap today, trying to install Version 0.98 from the original project … before I saw that this does not make any sense.
So I renamed the previous version back… when I discovered that the editor is not working…
I thought I did something wrong… so I reinstalled everything from scratch (git clone… as described in the link above…)
Funny co-incidence …
Has anybody got an idea how to debug this issue…? Why do I get a HTTP 302?
i had ran into the same issue with the editor for weathermaps no longer working, i switched to the stable release as described, and now my web gui is giving me a HTTP 500 Error when trying to access.
but when I run ./validate.php all appears fine?
other some device polling issues - which I can resolve. but the gui is my concern
Component
Version
LibreNMS
1.49
DB Schema
2019_02_10_220000_add_dates_to_fdb (132)
PHP
7.2.14
MySQL
5.5.60-MariaDB
RRDTool
1.4.8
SNMP
NET-SNMP 5.7.2
[OK] Composer Version: 1.8.4
Switching back to daily will most likely restore your GUI, its normally only safe to switch to the stable release on the day, or soon after the monthly stable branch is released.
If you are too far ahead on the daily branch and then switch back, you may be living in a future DB schema, but on old release code if that makes sense
