Fresh Install on CentOS7, everything was working GUI polling i added devices etc. I ran a validate to clean up any last errors PHP timezone etc…
Followed the suggestions in validate
Files:
/opt/librenms/config.php
/opt/librenms/composer.phar
After the changes suggested (above) site is not reachable and the DB appears disconnected
PHP Parse error: syntax error, unexpected ‘?’ in /opt/librenms/bootstrap/app.php on line 15
[OK] Composer Version: 1.8.4
[WARN] Your install is over 24 hours out of date, last update: Thu, 31 Jan 2019 16:40:20 +0000
Modified Files:
.editorconfig
.gitignore
.travis.yml
LibreNMS/Alert/Transport/Alertmanager.php
LibreNMS/Alert/Transport/Canopsis.php
LibreNMS/Alert/Transport/Elasticsearch.php
LibreNMS/Alert/Transport/Mattermost.php
LibreNMS/Alert/Transport/Msteams.php
LibreNMS/DB/Schema.php
LibreNMS/OS.php
LibreNMS/Util/Laravel.php
LibreNMS/Util/ModuleTestHelper.php
LibreNMS/Validations/Database.php
LibreNMS/Validations/Updates.php
app/Console/Kernel.php
and 103 more…
Files:
/opt/librenms/vendor/psr/simple-cache
/opt/librenms/vendor/psr/simple-cache/.editorconfig
/opt/librenms/vendor/psr/simple-cache/LICENSE.md
/opt/librenms/vendor/psr/simple-cache/README.md
/opt/librenms/vendor/psr/simple-cache/composer.json
/opt/librenms/vendor/psr/simple-cache/src
/opt/librenms/vendor/psr/simple-cache/src/CacheException.php
/opt/librenms/vendor/psr/simple-cache/src/CacheInterface.php
/opt/librenms/vendor/psr/simple-cache/src/InvalidArgumentException.php
/opt/librenms/vendor/psr/container
/opt/librenms/vendor/psr/container/.gitignore
/opt/librenms/vendor/psr/container/LICENSE
/opt/librenms/vendor/psr/container/README.md
/opt/librenms/vendor/psr/container/composer.json
/opt/librenms/vendor/psr/container/src
and 5110 more…
