I’ve got a handful of graphs that are appear functional but are not drawing the values they represent. They are drawing, just not the values fetched.
Everything appears to be functioning normally. No errors, no missing elements. The problem is that even though there is non-zero data being represented by the graph and successfully being fetched, the graph is drawing 0 values in the graph. See image below.
Other graphs on the same device, such as the current on the individual modules that this graph should show the aggregate of, display and draw as expected.
This malfunctioning graph on other devices of the same type and manufacturer are broken in the same way - data appears good, graph appears to be functioning normally, but the data being drawn is of 0 value rather than the actual values being fetched.
Graphs of the same sensor (“Current”) on other device types and manufacturers draw successfully. This would implicate the mfr specific aspects of the Librenms system, presumably bad MIBs, but the data is being polled, received, and accumulated properly and is showing in the legend as expected. It appears that it is not something with data gathering, processing, or storage but something breaking in the drawing of the data, and graphing of good data should be sensor/mfr agnostic. Data is data.
Any ideas where the disconnect could possibly be?
The graph, showing a good rrd command and good data, but drawing of zero value:
The data from a fetch for the same time period and same file mentioned in the graph command: fetch-values.txt
Validation:
librenms@libre2:~$ date
Fri 24 Jan 2025 11:08:43 AM CST
librenms@libre2:~$ ./validate.php
LibreNMS | 25.1.0-39-gef4b422f7 (2025-01-24T08:58:59-06:00)
DB Schema | 2025_01_22_194342_drop_storage_deleted (312)
PHP | 8.3.14
Python | 3.8.10
Database | MariaDB 10.3.39-MariaDB-0ubuntu0.20.04.2
RRDTool | 1.7.2
SNMP | 5.8
[OK] Composer Version: 2.8.4
librenms@libre2:~$
