and if you can show me for the measurements what code you used thank you
Here my test code file over root of librenms install, donât want to PR, cause ugly and snmp problems on devices
But ZTE C320 has very slow CPU and VERY SLOW AND BUGGY snmp replies⌠So i disappointed in these devicesâŚ
This can work normaly on small count of ONT/ONU on OLTâŚ
Device needs SNMP data caching on firmware level,or may be spike-nails in PHP code, to to align received or non-received data)
thank you very much check and see on the c300 how it goes back
Hello, I tried to install mib but it doesnât even want to see the processor or memory
You have make a great job !
Itâs possible to share your files for add ZTE olt on librenms ? This was helpful f
Hi, can I get your code? because this link is not valid anymore. I have this device but after add to Librenms only show basic information such as system up, location, sysname.
Hello ,
Someone help me to monitor OLT ZTe C300 CPU / FAN / TEMP I am trying but I am new to LibereNMS
Thank you
Boa noite,
Ă possĂvel compartilhar seus arquivos para adicionar ZTE olt on librenms?
anyone help me ? iâve already added ZTE olt on librenmas but librenms canât grab gpon traffic
Hi, your link is no longer available, letâs try to make pull-requests all the same. Can you reload the archive?
Hi!; any update??
Hello, I talked to the gentleman and I attached his archive, only it doesnât work on version 2 of Olt.
and hello aztec 102 I try to find you but I canât
password 123
But how did you do it?
@Razvan_Zmau After adding ZTE support, are you satisfied with the functionality?
Would you like to share the files again, please?
It show as deleted, thanks!
up +1
need to monitor this NE
