Grafana and Services
Hi
I have 10 services that I monitor externally with a TCP check via nagios plugins I have then attached these 10 services to the local host.
When I try to create grafana graphs for these services they do not appear to have any value.
When I check influxdb for them they dont not appear when executing the following command
select * from services
What does work is if a device has a single service attached to it then I can see the value. If a device has multiple services attached to it, the values do not appear in influxdb.
In Grafana try grouping by the service_id tag.
Hi
I tried that there is no data points.
I can’t seem to duplicate. Here’s what I’m seeing with 5 check_http services on localhost.
Fill and interval may be in issue. It should line up with your polling interval. I’m using the default 5m here.
Hi
Below are the services im a monitoring which are external and not services on localhost itself
This is my Grafana query
Question should I see entries in the influxdb for the above services when I check influxdb i dont see any entries
select * from services where (ā€œhostnameā€ = ā€˜localhost’)
Cool, that helps. I think the difference is I’m getting a byte count back from my check_http checks where check_tcp only gives you response time. If you run…
/opt/librenms/check-services.php -h 1 -d -v
(change -h to whatever device # your localhost is in LibreNMS)
…as librenms user I think you’ll see an error from InfluxDB that time is not a valid field name. I did quick kludge to ./includes/influxdb.inc.php that changes field key time to rtime and that writes successfully. It looks like @laf wrote the influxdb code so maybe he can weight in on if that’s a valid fix I can PR or if there’s a better way to handle it.
You’d need to show me a diff @slashdoom
Thanks slash…
A side question, have you come across smokeping metrics?
Do they get exported to influx DB so they can be graphed by Grafan.
I can’t seem to find them.
Not by librenms as we don’t do any generation of data for smokeping, smokeping would need to do that.
Thanks, @laf.
Error before…
Hi Laf
I came across the following article.
https://hveem.no/visualizing-latency-variance-with-grafana
not sure is this can be implemented into librenms
@slashdoom Seems an ok fix. Submit the PR :slight_smile:
Done. :+1:
https://github.com/librenms/librenms/pull/9358
Hi slashdoom
i am seeing this now influxdb
