root@cf631d29789e:/opt/librenms# ./validate.php
fatal: Not a git repository (or any of the parent directories): .git
Component |
Version |
LibreNMS |
DB Schema |
187 |
PHP |
7.0.18-1+deb.sury.org~xenial+1 |
MySQL |
5.6.35 |
RRDTool |
1.5.5 |
SNMP |
NET-SNMP 5.7.3 |
PHP Fatal error: Uncaught Exception: DateTime::__construct(): Failed to parse time string (@) at position 0 (@): Unexpected character in /opt/librenms/validate.php:113
Stack trace:
#0 /opt/librenms/validate.php(113): DateTime->__construct(’@’, Object(DateTimeZone))
#1 {main}
thrown in /opt/librenms/validate.php on line 113
root@cf631d29789e:/opt/librenms# git --version
git version 2.7.4
I already added timezone on php.ini file.
Any suggestion?
I’m assuming you didn’t do a git clone but used the zip from git to install?
I used docker container to install it.
I comment those validation and ran it again.
Component |
Version |
LibreNMS |
DB Schema |
187 |
PHP |
MySQL |
5.6.35 |
RRDTool |
1.5.5 |
SNMP |
NET-SNMP 5.7.3 |
[FAIL] We couldn’t find the following php extensions, please ensure they are installed:
snmp
mcrypt
[FIX] chown -R librenms:librenms /opt/librenms
/opt/librenms
/opt/librenms/config.docker.php
/opt/librenms/rrd
/opt/librenms/logs
/opt/librenms/config.php
[FAIL] Database: incorrect column (applications/timestamp)
[FAIL] Database: incorrect column (device_mibs/last_modified)
[FAIL] Database: incorrect column (device_oids/last_modified)
[FAIL] Database: incorrect column (mibdefs/last_modified)
[FAIL] Database: incorrect column (state_translations/state_lastupdated)
[FAIL] Database: incorrect column (users/updated_at)
ALTER TABLE applications
CHANGE timestamp
timestamp
timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP on update CURRENT_TIMESTAMP;
ALTER TABLE device_mibs
CHANGE last_modified
last_modified
ALTER TABLE device_oids
last_modified
ALTER TABLE mibdefs
last_modified
ALTER TABLE state_translations
CHANGE state_lastupdated
state_lastupdated
ALTER TABLE users
CHANGE updated_at
updated_at
timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP;
[FAIL] You have a different system timezone (UTC) specified to the php configured timezone (CDT), please correct this.
[FAIL] fping should be suid! [FIX] chmod u+s /usr/bin/fping
[FAIL] fping6 should be suid! [FIX] chmod u+s /usr/bin/fping6
To compare two paths outside a working tree:
