Hi folks,
I faced the graph issue today since 01:55 UTC on March 8th, and all of graph now showing since that time.
I can see the RRD command in each graph, but I got the error “ERROR: realpath(switch1/port-id5036.rrd): No such file or directory” when I try to execute it manually.
I also dump the rrd file and it showing NaN value since that time, but all of service still working, and there is no error message showing in librenms.log.
Does any folks faced similar issue before?
#Validate.php
Component | Version |
LibreNMS | 22.4.0-24-gc3cf52730 |
DB Schema | 2022_04_08_085504_isis_adjacencies_table_add_index (236) |
PHP | 7.4.19 |
Python | 3.6.8 |
MySQL | 10.3.28-MariaDB |
RRDTool | 1.7.0 |
SNMP | 5.8 |
[OK] Composer Version: 2.1.6
#RRD command in one of graph
rrdtool graph /tmp/6KbpfXP89WglpaI5 --alt-autoscale-max --rigid -E --start 1652005264 --end 1652026864 --width 1382 --height 300 -c BACK#EEEEEE00 -c SHADEA#EEEEEE00 -c SHADEB#EEEEEE00 -c CANVAS#FFFFFF00 -c GRID#a5a5a5 -c MGRID#FF9999 -c FRAME#5e5e5e -c ARROW#5e5e5e -R normal -c FONT#000000 --font LEGEND:8:DejaVuSansMono --font AXIS:7:DejaVuSansMono --font-render-mode normal DEF:outoctets=switch1/port-id5036.rrd:OUTOCTETS:AVERAGE DEF:inoctets=switch1/port-id5036.rrd:INOCTETS:AVERAGE DEF:outoctets_max=switch1/port-id5036.rrd:OUTOCTETS:MAX DEF:inoctets_max=switch1/port-id5036.rrd:INOCTETS:MAX CDEF:octets=inoctets,outoctets,+ CDEF:doutoctets=outoctets,1,* CDEF:outbits=outoctets,8,* CDEF:outbits_max=outoctets_max,8,* CDEF:doutoctets_max=outoctets_max,1,* CDEF:doutbits=doutoctets,8,* CDEF:doutbits_max=doutoctets_max,8,* CDEF:inbits=inoctets,8,* CDEF:inbits_max=inoctets_max,8,* VDEF:totin=inoctets,TOTAL VDEF:totout=outoctets,TOTAL VDEF:tot=octets,TOTAL CDEF:dpercentile_outn=doutbits,1,* VDEF:dpercentile_outnp=dpercentile_outn,95,PERCENT CDEF:dpercentile_outnpn=doutbits,doutbits,-,dpercentile_outnp,1,*,+ VDEF:dpercentile_out=dpercentile_outnpn,FIRST VDEF:percentile_in=inbits,95,PERCENT VDEF:percentile_out=outbits,95,PERCENT COMMENT:‘bps Now Ave Max 95th %\n’ AREA:inbits_max#D7FFC788: AREA:inbits#90B04088: LINE:inbits#608720:‘In ’ GPRINT:inbits:LAST:%6.2lf%s GPRINT:inbits:AVERAGE:%6.2lf%s GPRINT:inbits_max:MAX:%6.2lf%s GPRINT:percentile_in:%6.2lf%s\n AREA:doutbits_max#E0E0FF88: AREA:doutbits#8080C088: LINE:doutbits#606090:‘Out’ GPRINT:outbits:LAST:%6.2lf%s GPRINT:outbits:AVERAGE:%6.2lf%s GPRINT:outbits_max:MAX:%6.2lf%s GPRINT:percentile_out:%6.2lf%s\n GPRINT:tot:‘Total %6.2lf%sB’ GPRINT:totin:’(In %6.2lf%sB’ GPRINT:totout:‘Out %6.2lf%sB)\l’ LINE1:percentile_in#aa0000 LINE1:dpercentile_out#aa0000 HRULE:1000000000#000000:‘Port Speed 1 Gbps\n’ --daemon unix:/var/run/rrdcached.sock
