Hi, Im very new to LibreNMS so please forgive me but i have been tasked in taking over someones setup of LibreNMS who has left.
I have been trying to implement Rancid into the server and now the graphing appears to have stopped.
Here is my validate.php output.
Component | Version |
LibreNMS | 1.59 |
DB Schema | 2019_12_16_140000_create_customoids_table (152) |
PHP | 7.2.17-0ubuntu0.18.04.1 |
MySQL | 10.1.38-MariaDB-0ubuntu0.18.04.2 |
RRDTool | 1.7.0 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.9.1
Check your poll log
Devices:
ledcs6
clhhr1
gr1
dcr2
[FAIL] /var/run/rrdcached.sock doesn’t appear to exist, rrdcached test failed
Files:
/opt/librenms/html/plugins/Weathermap/images/f5.svg
/opt/librenms/html/plugins/Weathermap/configs/test1.conf
/opt/librenms/rancid_configs
/opt/librenms/rancid_configs/router.db
any ideas? Thanks
