You are in ‘detached HEAD’ state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by switching back to a branch.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -c with the switch command. Example:
git switch -c
Or undo this operation with:
git switch -
Turn off this advice by setting config variable advice.detachedHead to false
HEAD is now at 21b0e2034 Show OS definition in lnms config:get (#12819)
you know it is funny on the widgets on the dash board, it apprears that the data is still populating but the graphs aren’t populating because the top cpu devices do move around
