Hey folks, is there a way to use device grouping without pattern ? I’d need to group devices “manually”, following a criteria which is external to LibreNMS server.
Thanks a lot for your help
docs.librenms.org/Extensions/Device-Groups/
I haven’t seen this before to “manually group devices” If it not in the Database tables then-No.
you can make a feature request.
