Hard drive alert for volume space threshold, bits instead of %
Is it possible to change the Storage setting to warn me when the hard drive has < 200 MB versus a percentage?
Otherwise I have to calculate the byte size then convert to percentage size.
Help desk only wants to know when user’s computers has < 200 MB. That can vary widely depending on if the hard drive size is 60 GB or 250 GB.
Oh, and how can I add more fields to display in the column header of show all devices screen?
Thanks,
Terry
You can create alert that calculates the total space - used space > 200MB.
