[[email protected] librenms]# ./validate.php
Component | Version |
LibreNMS | 1.43-119-g6242f94 |
DB Schema | 268 |
PHP | 7.2.9 |
MySQL | 5.5.60-MariaDB |
RRDTool | 1.4.8 |
SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.7.2
[FAIL] The poller (CACTI) has not completed within the last 5 minutes, check the cron job.
[FAIL] The poller (LibreNMS) has not completed within the last 5 minutes, check the cron job.
[FIX] Check your poll log and see: http://docs.librenms.org/Support/Performance/
[FIX] Check the cron job to make sure it is running and using discovery-wrapper.py
