!Component | Version
!LibreNMS | 1.69-29-gf4ea49e38
!DB Schema | 2020_11_02_164331_add_powerstate_enum_to_vminfo (190)
!PHP | 7.4.11
!Python | 3.6.9
!MySQL | 10.5.7-MariaDB-1:10.5.7+maria~focal-log
!RRDTool | 1.7.0
!SNMP | NET-SNMP 5.7.3
!OpenSSL |
![OK] Composer Version: 3.0.1
![OK] Dependencies up-to-date.
![OK] Database connection successful
![OK] Database schema correct
![WARN] Your local git contains modified files, this could prevent automatic updates.
![FIX]:
!You can fix this with ./scripts/github-remove
!Modified Files:
!syslog.php
!*note: I modified syslog.php
Hi, i had the same problem with MSTeams, i think you should look at the format, actually HTML or a Markdown :
Maybe your alerts are trying to reach your chat group but without having informations to display, it means that you should create an alert template to manage the informations that you want to receive, for MSTeams, it’s JSON, so, as i can see, you should past a HTML file or a Markdown for the layout
figured it out.
the problem was in the env file settings
