HI,
I am trying to setup the JIRA Transport to open alerts into JIRA. I configured the JIRA Transport configuration on the Global Settings > Alert Settings page. When I click the button '“Test Transport” it turns red.
I tried checking the logs in logs/librenms.log but there is not information in the logs about the failure.
I can also telnet on port 443 to the JIRA server from the LibreNMS server. Finally the JIRA instance only requires the summary and description fields to be filled out.
Where can I get more information on the LibreNMS side about why this might be failing. Thanks.
