I have a service that i want to add to several devices.
Alll my devices are entered by hostname however I want to check the IP against the firewall logs that only have IP address how can I have librenms set a variable of the IP address to use to query based on the IP of the hostname.
You have not given enough details for anyone to be able to answer your question.
What is “check ip against the firewall logs”? for example.
