I just started using LibreNMS and so far it seems very well designed. I setup distributed polling using the official LibreNMS docs.
The problem I am having now is I see both pollers in the same group are having successful polls, but it feels like the polls aren’t being distributed across both pollers every five minutes.
My poller status can be found below:
I would think that the UI would show half of the total devices assigned to the poller group for each poller.
The details on my installation can be found at the following link:
https://p.libren.ms/view/raw/f11eaeb3
Please let me know if anyone has any ideas on what to check. Or if the data provided indicates distributed polling is working as designed.
Thanks,
Austin
