I’m using LibreNMS with InfluxDB 2.7 and Grafana.
I noticed that ifAlias is stored as a tag in InfluxDB. When an interface alias changes, InfluxDB creates a new series, so Grafana starts showing duplicate legends for the same interface.
For example:
Old alias: HE-100M
New alias: HE-1G
After the change, Grafana shows four legends instead of two (old In/Out + new In/Out).
Is this the expected behavior?
If so, what is the recommended way to build Grafana dashboards while allowing interface selection by ifAlias without creating duplicate series after interface alias changes?
Thanks!
My suggestion is to go to ports.inc.php and comment out the line that adds ifAlias to the data that is sent to the InfluxDB. (Unfortunately)
I wish that data had not been added, but at this point we can’t remove it without potentially breaking someone else. If we do that, I’d like to combine it with a fix so things are in better shape going forward. Needless to say, that is not on the horizon.
I understand now. Thanks for the explanation!
I only recently started using Grafana with LibreNMS for traffic dashboards, and I happened to run into these two issues. They’ve made me a bit hesitant to change interface descriptions.
