How to add custom oid
There is a way to add custom oid to librenms in order to make some graphs and bills ?
I have Juniper router and i want poll only certain oid created by junos’ filters.
How can i add this oid ? I read this file: http://docs.librenms.org/Extensions/MIB-based-polling/ but it’s quite complicated…
If it’s a specific OID then not really.
If it’s a tree within the MIB then the doc you linked to is correct.
What’s the OID?
The same problem. I try to add OID generated by filter in junos in Juniper.
For example:
1.3.6.1.4.1.2636.3.5.1.1.5.75.79.76.79.75.65.67.74.69.45.73.78.0.0.0.0.0.0.0.0.0.0.0.0.16.114.109.102.95.110.103.105.110.120.95.97.112.97.99.104.101.0.0.0.0.0.0.0
It is a counter
It needs to be the name iirc, i.e ifAlias.
There is some way, tool to translate this kind of OID to the name supported by librenms ?
Thare are some plans on librenms roadmap to support this kind of custom OID ?
That would be a huge improvement. I’d definitely like to shut down all the garbage that gets polled. In my situation, there is only %20 useful information at the moment. I don’t want any info from virtual or sub interfaces. And I don’t want the pkt/s graphs. bit/s is enough for me.
Again, it would be a huge relief for my nms server’s resources.
Cheers,
Sander
You know you can disable them, right?
Or manually inside each device or directly in config.php for all matches:
https://docs.librenms.org/Support/Configuration/#interfaces-to-be-ignored
No, I haven’t got that deep yet.
Thank you for pointing it out.
Hello, custom oid feature has been merged to master code. https://github.com/librenms/librenms/pull/10945
