I was told by support for a Fortinet appliance that the mib they use has been updated and that the OID showing in Librenms for our appliance is not correct.
Librenms says the device is using OID .1.3.6.1.4.1.12356.103.3.23
Support says to use OID .1.3.6.1.4.1.12356.103.2.1.2
I downloaded the mib.
What do I need to do to change the OID?
Component | Version |
LibreNMS | 1.50-34-g54c7ed3 |
DB Schema | 2019_02_10_220000_add_dates_to_fdb (132) |
PHP | 7.2.16 |
MySQL | 5.5.52-MariaDB |
RRDTool | 1.4.8 |
SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.8.5
