Component | Version |
LibreNMS | 1.32-4-ga1d7826 |
DB Schema | 209 |
PHP | 7.0.23 |
MySQL | 5.5.52-MariaDB |
RRDTool | 1.4.8 |
SNMP | NET-SNMP 5.7.2 |
[WARN] Your install is over 24 hours out of date, last update: Tue, 03 Oct 2017 20:38:40 +0000
Data from the latest poll is saved in the table device_oids, and RRD files are saved in the relevant device directory as mibName-oidName-index.rrd
SELECT * FROM device_oids return zero rows.
How can i check it?
Have added to global config $config[‘poller_modules’][‘mib’] = 1; and module for device also activated
but there is no any records at device_oids
