I’m trying to determine if there is some way I could use LibreNMS to graph the output of a shell command.
For example, I am trying to graph the # of entries in the MAC table of a switch and I have a shell script that returns the output from:
snmpwalk -v 2c -c public@100 10.1.100.1 .1.3.6.1.2.1.17.4.3.1.1 |wc -l
This returns an integer representing the # of MAC addresses in the table for VLAN 100, which is what I would like to be able to graph.
Output of validate.php
Component Version LibreNMS 21.3.0-89-g643c1ca3a DB Schema 2020_12_14_091314_create_port_groups_table (206) PHP 7.3.27-1~deb10u1 Python 3.7.3 MySQL 10.3.27-MariaDB-0+deb10u1 RRDTool 1.7.1 SNMP NET-SNMP 5.7.3 ==================================== [OK] Composer Version: 2.0.12
