How to Modify/Remove Alerts
Hi all, I am new to librenms and I have 2 questions for which I have been struggling but couldn’t find any answers
  1. After initial deployment, I was exploring alerts and alert transports, for that I used the default Service Down/Up alert and triggered it by creating a dummy service that would fail. Now I have deleted the service and that alert rule but that alert is still there. Is there a way to remove it?
  2. I added docker container stats in apps. I want to know if there is a way to create alerts for those containers that are visible in apps?
WARNING: Some networks were defined but are not used by any service: v6-net
LibreNMS 23.1.1 (2023-02-09T14:33:37-05:00)
DB Schema 2022_09_03_091314_update_ports_adsl_table_with_defaults (248)
PHP 8.1.15
Python 3.10.10
Database MariaDB 10.5.19-MariaDB-1:10.5.19+maria~ubu2004
SNMP 5.9.3
[OK]
[OK] MySQl and PHP time match
[FAIL] No active polling method detected
[FAIL] No active dispatcher nodes found
[FAIL] No python wrapper pollers found
[OK] Redis is functional
