I received “unpolled devices 15 min” warning on 3 of my devices and i wonder how to recover from this. Up until today, everyhting worked fine.
Its been couple of hours now since warning started to appear. Here is output from validate.php
Component | Version |
LibreNMS | 1.63-153-ge22a9fe5a |
DB Schema | 2020_04_06_001048_the_great_index_rename (165) |
PHP | 7.2.24-0ubuntu0.18.04.6 |
Python | 3.6.9 |
MySQL | 10.1.44-MariaDB-0ubuntu0.18.04.1 |
RRDTool | 1.7.0 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.10.6
[WARN] Could not check Python dependencies because this script is not running as librenms
Modified Files:
librenms.nonroot.cron
sudo chown -R librenms:librenms /home/librenms
sudo setfacl -d -m g::rwx /home/librenms/rrd /home/librenms/logs /home/librenms/bootstrap/cache/ /home/librenms/storage/
sudo chmod -R ug=rwX /home/librenms/rrd /home/librenms/logs /home/librenms/bootstrap/cache/ /home/librenms/storage/
Files:
/home/librenms/html/plugins/Weathermap/configs/Bosnet.conf
/home/librenms/composer.phar
