Suddenly my Magenta ink level isn’t available anymore.
Hardware: HP Officejet Pro 8600 N911g CM750A
Component | Version |
LibreNMS | 1.33-66-g1aa9713 |
DB Schema | 215 |
PHP | 7.0.22-0ubuntu0.16.04.1 |
MySQL | 5.7.20-0ubuntu0.16.04.1-log |
RRDTool | 1.5.5 |
SNMP | NET-SNMP 5.7.3 |
Checking toner magenta ink… SNMP[/usr/bin/snmpget -v1 -c COMMUNITY -OUqnv -M /opt/librenms/mibs udp:HOSTNAME:161 .1.3.6.1.2.1.43.11.1.1.9.0.4]
Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: .1.3.6.1.2.1.43.11.1.1.9.0.4
0 %
RRD[last hp8600.domain.lan/toner-4.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update hp8600.domain.lan/toner-4.rrd N:0 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]SQL[UPDATEtoner
settoner_current
=‘0’,toner_capacity
=‘230’ WHEREtoner_id
= ‘32’]
snmpwalk -v1 -c public -M /opt/librenms/mibs hp8600 .1.3.6.1.2.1.43.11.1.1.9
SNMPv2-SMI::mib-2.43.11.1.1.9.0.1 = INTEGER: 135
SNMPv2-SMI::mib-2.43.11.1.1.9.0.2 = INTEGER: 200
SNMPv2-SMI::mib-2.43.11.1.1.9.0.3 = INTEGER: 188
SNMPv2-SMI::mib-2.43.11.1.1.9.0.4 = INTEGER: 223
Full debug log:
Discovery https://p.libren.ms/view/6499c496
Poller https://p.libren.ms/view/975dd720
