While following https://docs.librenms.org/#Support/SSL-Configuration/#enabling-https-nginx
on Step 2
it has you add the following lines.
include snippets/ssl-example.com.conf;
include snippets/ssl-params.conf;
When running the syntax check sudo nginx -t
it says those files do not exist and when running the find . -name I’am unable to locate them
Please advise.
Thanks,
