[FAIL] Database: incorrect column (users/created_at)
ALTER TABLE users CHANGE created_atcreated_at timestamp NOT NULL DEFAULT ‘1970-01-02 00:00:01’;
Trying to get LibreNMS to pick up this device as a hp router ProCurve Secure Router 7102dl
I imported MIB Files from HP. However it still recognizes this device as a generic device and not a hp network device.
Any help will be greatly appreciated. Thank you very much
You will need to run this query in the database, try that and then run a discovery on that device.Should work after that.
Keep in mind that librenms is not mib based polling so you can’t just add a MIB and have it work, needs to coded into yaml file/php for that OS. What exactly are you trying to monitor? We have pretty good support for HP Procurves.
MariaDB [librenms]> ALTER TABLE users CHANGE created_at created_at timestamp NOT NULL 19 70-01-02 00:00:librenms;01DEFAULT
ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘1970-01-02 00:00:librenms’ at line 1
