I have set up the email alerting and it works fine. I would like tho to have as Fault or Description of the problem the same text that I see in the Alerts in the web page. Those are really well structured and one can pretty much instantly figure out what’s going on.
I will give you an example :
10.3.1.42 #1:[Runtime Current Value: 2 (runtime) low: 5, low_warn: 10, high_warn: 2000, high: 3000
This is what an alert looks in the web’s alert tab
If I am using the default template for the same alert this is what the alert looks like in my email :
sysObjectID = .1.3.6.1.4.1.318.1.3.27; sysDescr = APC Web/SNMP
Management Card (MB:v4.1.0 PF:v6.4.0 PN:apc_hw05_aos_640.bin AF1:v6.4.0
AN1:apc_hw05_sumx_640.bin MN:AP9631 HR:08 SN: ZA1616004594 MD:04/29/2016)
(Embedded PowerNet SNMP Agent SW v2.2 compatible); location_id = 13;
sensor_id = 628; sensor_oid = .1.3.6.1.4.1.318.1.1.1.2.2.3.0; sensor_descr =
Runtime;
I am using the default template with the code :
{{ $key }}: {{ $value[‘string’] }}
@endforeach
I’ve tried to figure out how to achieve the desired result reading the documentation but i couldn’t figure it out. So if anybody has a clue, please do share
