Hi there,
I have a problem with 2 Dell servers. I tried to poll IPMI data.
I configured IPMI tab on each servers and installed package “ipmitool” (I’m running ubuntu)
But data is still not getting polled.
I check some posts on the internet and some said to check ./validate.php script output.
I checked the output and most of the check are in “FAILED” state : ==========================================================
LibreNMS | d30e5660f942154bd72c1b3f6ff3846d3c1b7137
DB Schema | 199
PHP | 7.0.18-0ubuntu0.16.04.1
MySQL | 10.0.28-MariaDB-1~precise-wsrep
RRDTool | 1.5.5
SNMP | NET-SNMP 5.7.3
[WARN] Your install is out of date, last update: Mon, 10 Jul 2017 21:27:46 +0000
[FAIL] Database: incorrect column (dbSchema/version)
[FAIL] Database: missing index (dbSchema/PRIMARY)
[FAIL] Database: missing column (users/remember_token)
[FAIL] Database: incorrect column (users/updated_at)
ALTER TABLE `dbSchema` CHANGE `version` `version` int(11) NOT NULL DEFAULT '0';
ALTER TABLE `dbSchema` ADD PRIMARY KEY (`version`);
ALTER TABLE `users` ADD `remember_token` varchar(100) NULL AFTER `realname`;
ALTER TABLE `users` CHANGE `updated_at` `updated_at` timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP;
[FAIL] You have no timezone set for php. [FIX] http://php.net/manual/en/datetime.configuration.php#ini.date.timezone
Modified files:
librenms.nonroot.cron
What do you advise me to do ?
Can I fix these errors or do I reinstall LibreNMS and reimport ?
