A while back I put in my config.php file many regular expressions to ignore disks that I didn’t want to monitor, it worked great… at least I thought it did until today when I had a colleague call me and ask me to find out why a device in our system wasn’t displaying a drive which was nearly full.
After deleting the node and then adding it back in and still having the same outcome I choose to remove the regular expressions which I’d put in the my config.php a good while back. After doing so and running a discovery on the node it showed the drive in question. Out of curiosity I went in on the backend of my database and ran a query on the storage table for the device_id & storage_descr and found that many of our devices have the same serial (See below)!! Am I missing something, what is it that I need to do to ignore only the drive on the device in question?
## My regex expression to ignore a drive
$config[‘ignore_mount_regexp’][] = “/(.)30275f30(.)/”; #gcc16accs01, 10.30.1.201, D
$config[‘ignore_mount_regexp’][] = “/(.)56eab3f0(.)/”; #gcc16accs01, 10.30.1.201, E
$config[‘ignore_mount_regexp’][] = “/(.)ce209e6b(.)/”; #gcc16accs01, 10.30.1.201, F
$config[‘ignore_mount_regexp’][] = “/(.)40040e4b(.)/”; #gcc16accs01, 10.30.1.201, G
## Some of my query results
device_id, storage_descr
|545|C:\ Label: Serial Number e2d284f5
|352|C:\ Label: Serial Number e2d284f5
|279|C:\ Label: Serial Number e2d284f5
|278|C:\ Label: Serial Number e2d284f5
|277|C:\ Label: Serial Number e2d284f5
|280|C:\ Label: Serial Number e2d284f5
|544|C:\ Label: Serial Number e2d284f5
|126|C:\ Label: Serial Number e2d284f5
|455|C:\ Label: Serial Number e2d284f5
|129|C:\ Label: Serial Number e2d284f5
|463|C:\ Label: Serial Number e2d284f5
|534|C:\ Label: Serial Number e2d284f5
|351|C:\ Label: Serial Number e2d284f5
|619|C:\ Label: Serial Number e2d284f5
|350|C:\ Label: Serial Number e2d284f5
|524|C:\ Label: Serial Number e2d284f5
|515|C:\ Label: Serial Number e2d284f5
|519|C:\ Label: Serial Number e2d284f5
|542|C:\ Label: Serial Number e2d284f5
|560|C:\ Label: Serial Number e2d284f5
|559|C:\ Label: Serial Number e2d284f5
|131|C:\ Label: Serial Number e2d284f5
|530|C:\ Label: Serial Number e2d284f5
|547|C:\ Label: Serial Number e2d284f5
|127|C:\ Label: Serial Number e2d284f5
|546|C:\ Label: Serial Number e2d284f5
|541|C:\ Label: Serial Number e2d284f5
|540|C:\ Label: Serial Number e2d284f5
|539|C:\ Label: Serial Number e2d284f5
|537|C:\ Label: Serial Number e2d284f5
|535|C:\ Label: Serial Number e2d284f5
|532|C:\ Label: Serial Number e2d284f5
|531|C:\ Label: Serial Number e2d284f5
|525|C:\ Label: Serial Number e2d284f5
|529|C:\ Label: Serial Number e2d284f5
|509|C:\ Label: Serial Number e86948f6
|353|C:\ Label: Serial Number eca9cdc0
|618|C:\ Label: Serial Number eefd40fc
|462|C:\ Label: Serial Number f0c07c30
|130|C:\ Label: Serial Number f0c07c30
|553|C:\ Label: Serial Number f0c07c30
|550|C:\ Label: Serial Number f0c07c30
|538|C:\ Label: Serial Number f0c07c30
|276|C:\ Label: Serial Number f0c07c30
|372|C:\ Label: Serial Number f0c07c30
|552|C:\ Label: Serial Number f0c07c30
|551|C:\ Label: Serial Number f0c07c30
