Incorrect bandwidth
Hi forum , I need a bit of help, I have a link with my 50MB provider on my interface and when I review the 24hour juice, it tells me that I have consumed 2.56MB of output, I have a network with 60 users and about 20 users surf without restriction.
version of librenms
LibreNMS 1.41-8-gd9ceaf7
DB Schema 253
PHP 7.1.14
MySQL 10.1.31-MariaDB
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
[OK] Composer Version: 1.6.5
Modified Files:
logs/.gitignore
mibs/junos/mib-jnx-jdhcp.txt
LibreNMS reports what the device sends it unmodified. What do you expect to see? Do you have a number from something else to compare?
Hello rickygm,
I see more than 29GBytes (27 of them being incoming traffic). And the graph shows activity that is fully compatible with a 50Mbits/s link.
I support you misread the legend at the bottom. 2.56Mb/s is the maximum instant upload during the last 24 hours. The value is the “max” of the blue graph, taken at around 8AM.
Bye
Hi, for now no, I’m talking to the service provider to compare the metrics
