thank you
Is it necessary to do this to uninstall php55
mkdir /root/configphp
cp -Rf /etc/php* /root/configphp
yum remove php php-cli php-common && yum clean all
after i install php7 like this the two version does not in conflict because
This is what happens when i install php55
Yeah, it seems as though there is a conflict. (BTW, don’t copy your old PHP config to PHP 7, use the one provided with the package, it has good defaults)
Thank you very much for the history of php it’s good it works now i will try to use influxdb
but when i run the git branch --set-upstream-to=origin/master master the option -set-upstream-to=origin/master maste are unknown what do you think if i use this git branch -u origin/master master
and i have reviewed the installation and in have some problems with the validation of installation
and now They save int influxdb but hiw can i see the value ?
but the Data is not update in rrd i think now they don’t work with rrd
They have a configuration in order to work with two databases ???
Maybe your version of git is too old for that command.
For viewing data in influx, you need to use something like Grafana. I’ll warn you now that you need to have some level of knowledge on how to use it and retrieve / display data.
Thank you very much @murrant and @laf
now i can to see the metrics on grafana
Just a small confirmation
The data to recover are well send in the two databases influxdb and rrd and librenms displays the metric apartire of rrd that is it.
thank you @murrant
I have another last question
In fact my team use Opentsdb for two years and others also intervene with OpenTsdb and my question is
"Are OpenTsdb and Influxdb compatible?"
In order that I can think of a migration solution from Influxdb to OpenTSDB
Or directly include a method that would allow librenms to save in OpenTSDB in addition
But I do not really think that Inluxdb that uses the LevelDB system is compatible with Openttsdb which uses hbase1
That is outside of my area of knowledge. I’m pretty sure that InfluxDB is not a drop in replacement for OpenTSDB, but your other things might be able to use influxdb and possibly even port data to influxdb.
