Hi!
I’m new to librenms and was planning on migrating from cacti.
When I did my first wizard, I stumble upon the following error on stage 2:
Starting Update…
SQLSTATE[HY000] [2002] No route to host (SQL: select * from information_schema.tables where table_schema = librenms and table_name = migrations and table_type = ‘BASE TABLE’)
Error!
I know that this is normally related to routing problem but :
- no firewall
- no selinux
- the database server is on the same subnet
- the stage 1 completed. (so connection to database is working)
- I can telnet 3306 and ping the database server from the librenms server.
- if I hardcode the hostname in “vendor/laravel/framework/src/Illuminate/Database/Connectors/MySqlConnector.php” , it is working.
You can check all the detail of my installation in the pastebin : https://p.libren.ms/view/0f3fec22
Thank you for your time!
