I’ve using alert rule :Interface Errors Rate greater than 100
ports.ifOutErrors_rate >= “100” || ports.ifInErrors_rate >= “100”
on
Aruba switches
and dont get it to work.
I have on port now that are on 100+ MPPS, but there is no alerts.
So I tried to trim down to get an alert…
When I reached the limit to below 4, all switches started to report alerts…
I ll really cant get the hang on it
Then i tested " ports.ifOutErrors != 0 OR ports.ifOutErrors != 0"
That didnt identify the problem on the switch.
LibreNMS identifies the port with a red Flag, but still i cant identify and start an alert.
Any IDEAS out there?
