I have configured IPSLA udp-jitter on an ASR9k that I am also monitoring via LibreNMS. I am able to see that it detects udp-jitter IPSLA graphs, but it is missing some information. Based on #3550, it seems as if the IOS-XR platform is reading different OID’s for One Way Latency and Jitter. I don’t see ICPIF being monitored at all based on the ipsla output from the IOS-XR OS (likely that it’s not supported under IOS-XR? I didn’t look too much into it).
Here is the output I have for a udp-jitter IP SLA instance:
Entry number: 26
Modification time: 13:57:13.976 EST Tue Aug 14 2018
Start time : 13:57:13.981 EST Tue Aug 14 2018
Number of operations attempted: 284
Number of operations skipped : 0
Current seconds left in Life : Forever
Operational state of entry : Active
Operational frequency(seconds): 20
Connection loss occurred : FALSE
Timeout occurred : FALSE
Latest RTT (milliseconds) : 2
Latest operation start time : 15:31:34.987 EST Tue Aug 14 2018
Next operation start time : 15:31:54.987 EST Tue Aug 14 2018
Latest operation return code : OK
RTT Values:
RTTAvg : 2 RTTMin: 2 RTTMax : 3
NumOfRTT: 10 RTTSum: 21 RTTSum2: 45
Packet Loss Values:
PacketLossSD : 0 PacketLossDS : 0
PacketOutOfSequence: 0 PacketMIA : 0
PacketLateArrival : 0 PacketSkipped: 0
Errors : 0 Busies : 0
InvalidTimestamp : 0
Jitter Values :
MinOfPositivesSD: 0 MaxOfPositivesSD: 0
NumOfPositivesSD: 0 SumOfPositivesSD: 0
Sum2PositivesSD : 0
MinOfNegativesSD: 0 MaxOfNegativesSD: 0
NumOfNegativesSD: 0 SumOfNegativesSD: 0
Sum2NegativesSD : 0
MinOfPositivesDS: 0 MaxOfPositivesDS: 0
NumOfPositivesDS: 0 SumOfPositivesDS: 0
Sum2PositivesDS : 0
MinOfNegativesDS: 1 MaxOfNegativesDS: 1
NumOfNegativesDS: 1 SumOfNegativesDS: 1
Sum2NegativesDS : 1
JitterAve: 1 JitterSDAve: 0 JitterDSAve: 1
Interarrival jitterout: 0 Interarrival jitterin: 0
One Way Values :
NumOfOW: 10
OWMinSD : 1 OWMaxSD: 1 OWSumSD: 10
OWSum2SD: 10 OWAveSD: 1
OWMinDS : 1 OWMaxDS: 2 OWSumDS: 11
OWSum2DS: 13 OWAveDS: 1
From #3550, I am able to see jitter values from the snmpwalk:
$ snmpwalk -c community -v2c node .1.3.6.1.4.1.9.9.42.1.3.5.1.64
iso.3.6.1.4.1.9.9.42.1.3.5.1.64.26.401509614 = Gauge32: 1
iso.3.6.1.4.1.9.9.42.1.3.5.1.64.26.401869614 = Gauge32: 1
iso.3.6.1.4.1.9.9.42.1.3.5.1.64.28.401509614 = Gauge32: 1
iso.3.6.1.4.1.9.9.42.1.3.5.1.64.28.401869614 = Gauge32: 1
$ snmpwalk -c community -v2c node .1.3.6.1.4.1.9.9.42.1.3.5.1.63
iso.3.6.1.4.1.9.9.42.1.3.5.1.63.26.401509614 = Gauge32: 2
iso.3.6.1.4.1.9.9.42.1.3.5.1.63.26.401869614 = Gauge32: 2
iso.3.6.1.4.1.9.9.42.1.3.5.1.63.28.401509614 = Gauge32: 2
iso.3.6.1.4.1.9.9.42.1.3.5.1.63.28.401869614 = Gauge32: 2
But with that, I am not seeing any values graphed. Nor is the poller.php showing any values as well (snippet of poller.php for the cisco-sla module):
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Otv -M /opt/librenms/mibs:/opt/librenms/mibs/cisco udp:HOSTNAME:161 sysUpTime.0]
sysUpTime.0: Unknown Object Identifier (Sub-id not found: (top) -> sysUpTime)
SLA 26: jitter ()... 1ms at 2018-08-14 15:38:34\nRRD[update node/sla-26.rrd N:1 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]RRD[update node/sla-26-jitter.rrd N:0:0:0:0:0:0:U:U:U:U:U --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]The following datasources were collected for #26:
Array
[rtt] => 1
[PacketLossSD] => 0
[PacketLossDS] => 0
[PacketOutOfSequence] => 0
[PacketMIA] => 0
[PacketLateArrival] => 0
[MOS] => 0
[ICPIF] =>
[OWAvgSD] =>
[OWAvgDS] =>
[AvgSDJ] =>
[AvgDSJ] =>
I did notice that the One Way latency OID’s for the XR appears to be the following:
rttMonLatestJitterOperOWSumSD | 1.3.6.1.4.1.9.9.42.1.5.2.1.33
rttMonLatestJitterOperOWSum2SD | 1.3.6.1.4.1.9.9.42.1.5.2.1.34
rttMonLatestJitterOperOWMinSD | 1.3.6.1.4.1.9.9.42.1.5.2.1.35
rttMonLatestJitterOperOWMaxSD | 1.3.6.1.4.1.9.9.42.1.5.2.1.36
rttMonLatestJitterOperOWSumDS | 1.3.6.1.4.1.9.9.42.1.5.2.1.37
rttMonLatestJitterOperOWSum2DS | 1.3.6.1.4.1.9.9.42.1.5.2.1.38
rttMonLatestJitterOperOWMinDS | 1.3.6.1.4.1.9.9.42.1.5.2.1.39
