Is Librenms affected by vulnerable to CVE-2026-109618 and CVE-2026-109619
As librenms uses PHP, your Linux distro in use most likely would need PHP updated to a patched version, check your distro patch / security bulletins. For example, ubuntu - php2shell (CVE-2026-109618 and CVE-2026-109619) – PHP critical vulnerability fixes available | Ubuntu
I patched mine late last or early this week.
@Manoj_Nr No, LibreNMS is not affected, but PHP is. You must make sure you are running on a patched version of PHP.
No update of LibreNMS is required, only PHP itself.
